Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Note II is een smartphone die bekend staat om zijn combinatie van een groot beeldscherm en software die geoptimaliseerd is voor een geïntegreerde, in het toestel opbergbare stylus.
Not registered to Network
I bought this unlocked Samsung Galaxy Note II about 9 months ago, and it worked perfectly. All of sudden, it stopped recognizing the network. It keeps saying that it's unable to connect, but it can recognize T-mobile signals. It looks like the phone knows that there is a signal but is unable to connect to the network. Everything on this phone has worked very well other than this network problem. I can use WiFi perfectly, but I cannot make or receive calls. Would you please help me? Thank you so much.
Is dit een goede vraag?
Score 175
12 opmerkingen
same problem, really frustating!
door
Aya Drilon' link it's the most helpful.
door
my matter galaxy note 4 not registered on network please my matte solved
door
me too its just too devastating
door
For T-Mobile, have you contacted them to see if a new SIM is needed? Normally they swap SIMs for little to no charge.
door
7 commentaren meer tonen
Voeg een opmerking toe
11 Antwoorden
Filteren op:
Gekozen oplossing
hello, i have found a solution that works here it is http://www.technobezz.com/fix-samsung-ga...
Was dit antwoord nuttig?
Score 16
1 Opmerking:
i) If Your E5377T Device shows 0 attempts 10
door
very simple:
Go to [settings]-[More settings]- [mobile networks]- [network mode] and then select [GSM/WCDMA (auto mode)]
Score 13
4 opmerkingen:
this helped...thanks a lot
door
this helped. thanks a lot!
door
not working my note 2 n7100 4.4.2 is already gsm/wcdma outo mode.
door
My Note 2 isn't connected to a provider. My wifi connection is strong but it still says"no Internet connection"...I just want to use on WiFi not as a phone...
door
Easiest, but not likely: your SIM is shifted or the contact continuity has degraded. Shut off phone, pull out sim and check condition of contacts on SIM. I've had to clean a really old and corroded SIM with the eraser on a pencil before. I stuck the center of the eraser over each contact pad on the SIM and gave a dozen or so back-forth twists to rub the oxide buildup away, repeating in a grid pattern to cover the entirety of the contacts. Once done, blow off any loose debris and pop the SIM back in and give it a go., Pay attention to SIM pad to phone contact alignment, particularly if you're using a cut down full size SIM, also.
IF that doesn't work, there's another common, but really annoying firmware corruption issue that occurs somewhat often:
1. Go to the phone dialer and enter *#*#4636#*#* to pull up the hidden testing menu.(4636="INFO") and the menu should pop up as soon as you press the last * key, without having to hit dial.
2. pick first menu option "Phone information"
3. The first line on the phone info menu should be IMEI. Compare it to the IMEI printed on the label under the battery.
If they don't match, it's likely that the IMEI from the menu got overwritten or corrupted somehow.
At boot, Your kernel pulls a config file from a factory-programmed, device-specific config file in the EFS folder on the root of your internal stoirage. If the EFS has bad info, the IMEI will get set to a single, specific value that is the same on every GN2. I don't remember the valyue offhand, but it's mentioned on XDA a few times in the forums.
Hopefully, you have a backup of default and proper EFS partition handy that you can restore in recovery mode.
Barring the existence of a valid backup, I think there are a few, complex methods to flash a generic stock image via ODIN, then you can go into root explorer and manually update the file(s) with the appropriate values.
I had this happen anout 2 weeks ago and freaked out because I couldn't find an EFS image backup in CWM recovery. After about a day of dinking around with no success, I realized I had a TWRP backup from when I first rooted the phone, so I restored just the EFS partition image via the advancved backup menu in the PhilZ CWM recovery.
After flashing and rebooting, the SIM got provisioned on the network, but my phone app and gvoice kept crashing. I updated my to a later, fresh version after doing a cache/dalvik/factory wipe from recovery and it's back 100% now.
Update
Make sure you're flipping the # and * characters on both ends:
*#*#4636#*#*
start: * before #
end: # before *
Score 8
2 opmerkingen:
IMEI is not the same on back of my phone. Can you please explain me more, if I can fix it without root, or I have to root it, please?
Thank you
door
after flashing so many ROM, my device N7100 is factory mode on and not registered on network Message is coming. i dont have any backup of EFS also, bymistake i format that also.please help in this case
door
Bro here is the solution for your device. Do refer the below link.
Solution for Not Register On Network
Score 5
*#0*#
this is for the tmobile version
Score 4
1 Opmerking:
What more do u do when u enter this code
door
There are a lot of reasons you may be facing the not registered on network problem . These are
1 Nulled IMEI Number
2 No Service
3 Unknown Baseband
4 Outdated Firmware
5 Radio is off
You can check your IMEI number by dialling * # 0 6 # , you will see 0000 or nulled if it's corrupted.
If you have an Unknown baseband then i suggest your to backup and restore your EFS Folder.This folder contains all the information about your phone.
Simply go to settings , then go to about, then hit the update button.This will update you to an higher OS version
If your radio is off , dial *#*#4636#*#* . Then click Phone Information.Run a quick Ping. After, Turn Radio OFF/ON
I found all the information on - http://www.technobezz.com/fix-samsung-ga...
Score 2
1 Opmerking:
door
I solved this problem (No register Network)by using SPT box.
1.reset default EFS.
2.writing super imei.
Score 2
Is it not taking any network signal or it seldom takes and sometimes doesn't take? If it is not at all connecting to any network then it can be software issue but if it is switching between getting or not getting signals then it be a hardware issue aswell
Score 1
Tengo un s3 i 747, lo actualice a androi 5.1.1 y ahorra me dice No se inserto Ninguna Tarjeta SIM, pero si recibe msj y llamadas, no me levanta datos. y el APN dice que La configuracion del nombre de punto de acceso no esta disponible para este dispositivo, ¿que hago? por favor ayudenme.
Solving “Not Registered on Network” on Android?
Method 1: Restart the Android
Method 2: Turn Flight Mode on/off
Method 3: Toggle SIM off/on
Method 4:LTE/VoLTE Connection switching
Method 5: Remove SIM Card and Re-insert.
Method 6: Reset Network Settings
Method 7: Manual Network Mode
Method 8: Clear Android Cache
Method 9: Enter Service Mode (Samsung phone)
SOLUTION TO IMEI PROBLEM https://www.youtube.com/watch?v=AzTkb_qn...
1 Opmerking:
My mobile screen is often showing mis call at 05.00 hrs on screen
door
Voeg je antwoord toe
Banafsheh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 70
Altijd: 258,555
