Ga door naar hoofdinhoud
Model A1236 / 4 or 8 GB capacity
134 Vragen Bekijk alle
Vraag afgerond
USB port does not work on computer :(
Ok, so I have an extremely beat up 3rd gen iPod nano, but the only way I can charge it is putting it on an iPod dock, which will charge it but not play music while it on the dock (you can connect a stereo plug into it and works fine.) In addition, it is not recognized by the computer when connected via usb and does not charge. How do I fix?
TL;DR: charging works only when connected to iPod dock, data works never... why/what do?
EDIT: The cable is not faulty, it works with other devices, and I have tried other cables.
Is dit een goede vraag?
Score -1
2 opmerkingen
This is the exact problem I'm having with same (nano 3rd gen) yet other iPods work with same cables and ports perfectly; is there any further info?
door
get the ipod cable, you can get it at waltmart for $20
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Mark Biernacki, I do realize that this is a very old question and somehow, somebody dug it up:-) I am certain that after 19month you got your Ipod fixed. Anyhow, the thing that I would do is to replace your battery. It works on a dock since the power supply is greater, your iPod's battery does not charger on a USB since it only supplies 500mA.
Was dit antwoord nuttig?
1 Opmerking:
Thanks for replying, I will have to try this. BTW I havent fixed it yet :P
door
Het nuttigste antwoord
Most likely a bad or a cheap cable. I've seen this a lot. Get a good one.
Score 2
Most likely a faulty cable but I have seen the opposite, where an ipod will not play on a dock, but is all ok via USB etc. Not sure if it is a hardware or software problem. Possibly worn socket pins?
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,019
