FULL message on LCD
I purchased a new Ultra SanDisk 64GB for an upcoming trip. I have formatted the disk, but the LCD on my D80 says "Full" and will not allow me to shoot. If I replace with the current 16 GB disk, everything works OK. What can I do?
Is dit een goede vraag?
9 opmerkingen
Did you format your new card?
door oldturkey03
The following SD memory cards have been approved for use in the D80 digital SLR. All cards of the designated make and capacity can be used, regardless of speed."
Nikon 512MB, 1GB
SanDisk 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Panasonic 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Toshiba 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1
All SD memory cards indicated above can be used regardless of their transfer speed.
Lexar Media
256 MB, 512 MB, 1 GB
Platinum II (60x) series: 512 MB, 1 GB
Professional (133x) series: 1 GB, 2 GB1
1 If the memory card will be used with a card reader or other device, the device must support 2-GB SD memory cards.
2 SDHC-compliant.
from https://support.nikonusa.com/app/answers...
So according to Nikon, even your 16GB should not be working;-) try to format and see what you come up with.
door oldturkey03
remove battery from camera and wait about 30 seconds then then replace and all should be ok
door james cleary
Thanks @james cleary, it worked.
door moshayedi.mahdi
I'm having the same problem, k have a SanDisk 64gb in my d80 and it's formatted to Fat32 and it still says full
door Alize' DeJesus
4 commentaren meer tonen
