Ga door naar hoofdinhoud
The Nokia E71 is a smartphone from the Eseries range with a QWERTY keyboard targeting business users worldwide. It was released in 2008.
How to get the cover off Nokia E71 to remove dust
Is there a good way to pry off the front cover so that you can dust off the screen underneath. Worried about cracking some connectors if I go about it the wrong way. Pretty tight fit and not sure if it is designed to be taken off.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I hate to just Google it for you, but I Google'd it for you. Here it is :
Nokia E71
Regards,
Frank
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks! (Feel really stupid.....)
Good photo guide. Note: you will need one of those special octagonal screwdrivers (the tiny ones) to undo the screws in the second picture
door
"special octagonal screwdrivers" - it's called Torx - the size in that case was T4 ;-)
door
Look for this procedure:
Disassembling Nokia E71 Complete disassembly
Score 1
Voeg je antwoord toe
Tze Wen Leow zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 12,064
