Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Vragen Bekijk alle
Vraag afgerond
What is the best way to replace the digitizer?
Do I need a hair dryer or some source of heat to do this? I have it mostly apart (trying to replace the digitizer and maybe LCD) but it is really stuck together hard. Even if I get it apart, will it be ok if I just stick it back together?
Any tips on this area of the repair of the iPhone 1st gen would be great, thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check out this video. Even though it is a 3G iPhone at about 3 minutes into the clip you will see him use a heat gun for removal of the digitizer.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Nice reference +
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,911
