Why wont my engine fire or run?
It will turn over. but it will try to start up on starting fluid. tjen it quits trying to run just turns over. whats wrong??
Is dit een goede vraag?
I would suspect fuel delivery system and the high voltage circuitry.
Was dit antwoord nuttig?
It has all kinds of fuel pressure. and yhe high voltage circuitry? how might i check that?
Search this site: bobistheoilguy.com Look in the Automotive and Mechanical forums.
You will also need basic voltmeter and ohmmeter test equipment.
i have almost the same problem my dodge neon wont even turn over it doesnt even do a click what do i do ? can anhy body help me
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 291
similar problem on our car turned out to be a loose fuel pump connector..
door pollytintop
