Ga door naar hoofdinhoud
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Vragen Bekijk alle
Is iPad 4 LCD the same as the iPad 3?
I know the digitizer for the iPad 4 is the same as the iPad 3. We have repaired iPad 4 and have had no problems. But is the LCD the same connection and part? Can I use the iPad 3 LCD's I Have in stock to replace a broken LCD for a client?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
They are exactly the same, exchangeable completely.
Was dit antwoord nuttig?
Score 8
yes, the same. iPad 3 screen will light up just fine in the ipad 4.
Score 7
Hi,
According to me iPad 4  Pretty much the same as the iPad 3
Score 1
Interesting stuff to read about iPad mini' display. Keep it up.
Score 1
The answer is yes, Ipad 3 LCD and Ipad 4 lcd can be perfectly used for each other, which has been verified by Jackie's Apple repair.
Of course different, You can get the answer from this website:
This is iPad 3 screen: http://www.etradesupply.com/apple-the-ne...
This is iPad 4 scren: http://www.etradesupply.com/oem-apple-ip...
Score -2
5 opmerkingen:
WRONG! They are the same. If you do not know, do not answer. People rely on these answers to be right!
door
Thank you David. I was confused by this persons reply.
door
@soros I recognize that this is a wrong answer, but it is still an answer. We just had a discussion about this very subject on here https://meta.ifixit.com/Answers/View/942...
We should not be the judge about how good or how bad an answer is, for as long as it is not misleading or written with any malicious intent. Feel free to comment on those answers and utilize your voting powers to either validate or disprove an answer.
door
@oldturkey03 il keep that in mind.
Still learning the things around here.
door
@soros no problem at all. Just something to keep in mind...
door
Voeg je antwoord toe
SaqibQ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 5,166
