Ga door naar hoofdinhoud
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
Replacing motherboard in Asus Eee PC 1005HA
Hello, after few years my eee pc 1005HA is broke. I send it to IT shop for repair. they said some parts on motherboard has died. They said i need to replace the motherboard. After few search on the web, i found that the are 3 different laptop of this model. Question is. Does all motherboard of this type of laptops can fit ? I dont care about the differents in processors or bluetooth. I just need to know does they fit in the body of other models ? Thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
p1nky, the difference is usually just the processor and other on-board architecture, while maintaining the same footprint. Always check with the vendor to make sure that you come as close to what you currently have. This will show you how to change the motherboard. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
p1nky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 2,581
