Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Vragen Bekijk alle
Vraag afgerond
80gb harddrive for 5th generation compatible with iPod Classic?
I have a bad 80gb iPod Classic that I can't restore or do anything with so I want to replace the hard drive to see if this is the problem. Will a hard drive for an iPod 80gb 5th generation video work with the iPod 80gb Classic?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yes, because they use the same connector. However, from my understanding it needs to be a ATA ZIF drive, and you can't go higher then 160GB with them in that format.
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
The hard drive works great but now there's a new problem. I can't get the iPod to close up. This is the thin classic and the new hard drive is thicker than the original. Will a 160gb back plate work to replace the 80gb back plate?
door
You may have ruined your backplate clips... get a new back and try that
door
The iPod Classic 160 GB is a 6th generation and the casing will NOT fit the 5th generation.
door
i would think that it would work, but i cant say that it will for sure. if you have the 160gb backing give her a shot and see if it works thatd be what i do.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 5,209
