Ga door naar hoofdinhoud
1,83 GHz Core Duo of 1,83, 2, of 2,16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Which superdrive to purchase?
Hi,
I have a late 2006 iMac (17" Intel, 2.0 GHz Core 2 Duo). It has a Matshita UJ-846 combo drive which has been confirmed dead and requires replacement. I believe that's a Panasonic drive (not a Pioneer). Ifixit.com has 2:
12.7 mm PATA 8x SuperDrive (UJ-85J)
12.7 mm PATA 8x SuperDrive (UJ-875)
What is the difference between the two and which one should I buy? They are both the same price, but one of them is out of stock. Please let me know if any further information regarding my computer model is required in order to appropriately answer this question. Thanks in advance!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
To get the correct part, write directly to iFixits parts department and they will direct you as to which on you need. Here's the link: http://www.ifixit.com/Info/contact
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Good advice + Ralph
door
I have the same superdrive model in my 20-inch, late 2006, Intel. 2.16 GHz Core 2 Duo iMac that needs to be replaced. It reads DVDs. Reads and burns CDs. But will not burn a DVD. Jason did you replace yours? If so with which model how is it working for you?
Thanks,
Sid
Score 1
1 Opmerking:
I would bet that after 11 months this issue has been resolved.
door
Yes, the issue was resolved. I just purchased whichever one was in stock and installed it myself. Everything works great now.
Score 1
There doesn't seem to be much difference, they're different model numbers, but iFixit says both will work with your computer, so it's up to you do decide (one is more costly). Obviously then, if you're in urgent/dire need, then you should get the one that is in stock.
Voeg je antwoord toe
Jason Morais zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 2,255
