Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
My iPod wont play out loud. Any ideas?
it will play thru earphones and speakers but not on its own.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Jo Boyle, it is possible that you have a stuck audio jack, it may believe that the head phones are still plugged in, even if they are not. Try to clean the jack with a few drops of isopropyl alcohol and either a vacuum cleaner or a some puffs of compressed air. If that does not work, you may have to replace it.
Was dit antwoord nuttig?
1 Opmerking:
thanks, have already tried jacking/unjacking earphones several times & blowing into jack. Its still under warranty so think it will have 2 go back.
door
Did you open it up? Sometimes if you are not careful you can damage the speaker.
1 Opmerking:
No, not been opened up, but thanks for the tip.
door
Voeg je antwoord toe
Jo Boyle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 802
