Make sure your USB adapter drivers are functioning well and up to
Is the external drive working fine in another system? If you've not tried it, please do.
Also try to see if another external hard drive works fine on your system.
If another external drive works fine on your system, then the problem is with your external hard drive. Your external hdd is damaged.
Get a data recovery software such as EaseUS recovery tool by downloading and installing it, (you can use the trial version), use it to open the external drive, you would see your files there. Recover what you want by saving them in another drive.
If another external hard drive doesn't work fine on your system, then go to Google, search for the USB drivers for your system brand and model. Download it.
Go to device manager, under USB, uninstall the USB adapters.
Then go back to the USB driver you just downloaded, install it.
Restart your computer.
Test your external hard drive on it.
41 opmerkingen
What happened just before you lost access? Did you disconnect it without dismounting the volume or when the system was powered off? Did the power supply get disconnected while it was writing a file (or the AC power go out)? What is your system PC or MAC?
door Dan
Dan,
Disconnect it without dismounting. M used with my laptop. I can see it in device manager but not showing in my computer. is it possible to backup the data?? plz help
door Raj
Raj you'll need to help me here a little. What is M and did you disconnect the drive without dismounting? I still need to know what OS Windows or Mac OS-X and what version.
door Dan
Sorry Dan its typo mistake. I am using Windows Vista home premium. I didn't disconnect the drive without dismounting.
door Raj
OK, good start. Can you explain what happened to the drive did you bang or drop it while it was running or when it was off? The more detail will help.
door Dan
36 commentaren meer tonen
