Ga door naar hoofdinhoud
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
20 Vragen Bekijk alle
Why is the washing filling with water?
Why is the washing machine filling up with water when it is in a no use mode?( or resting mode) between wash loads if we don't use it for awhile you have to stand back or else water pours outof the machine
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
obbarius, "this could be caused by a water inlet valve malfunction. The valve has a diaphragm that is electronically controlled. It closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat properly. You can try and clean the valve with vinegar to remove any sediments. Clean it with running water after.You will need to remove the valve to do this. Should the cleaning not resolve the issue, you may have to replace the valve. For that you have to open the machine from the top:"
Remove the three screws holding the top panel in place.
Disconnect the hoses and electrical connections to the water inlet valve.
Remove the mounting screws holding the water inlet valve.
The part number for the valve is 906483 and a replacement valve is available at places like this. Attached image is from here.Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Internally you have a set of solenoid valves which controls the water flow from your hoses. I suspect one is leaking. For now make sure you turn the water supply valve off when your done with the washer until you get it fixed.
I strongly recommend installing a sensor valve which turns off the water at the hose feeds that way if a hose lets loose you don't have a swimming pool in the basement (example unit). Also consider getting a grit filter on the waterline entering your house as it's likely something has jammed up the solenoid that flushed into it (example unit).
To isolate out which valve needs replacing, turn off the water of one side only (hot or cold) if you have a valve some where along the line during the night and see if the tub has filled up. You should be able to deduce which solenoid is bad. If you don't you'll need to get a cap to fit over one of the hose connections to isolate out which side.
Score 3
My machine kept stopping durning the cycle and be full of water. The machine is top heavy with storage space underneath. So i filled the storage space with heavy stuff to balance it and it stopped the problem.
Voeg je antwoord toe
obbarius zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 24,440
