Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Change LCD and backlight ic, still black screen when powered on
I broke the screen on my iPhone, then replaced it and now the apple logo pops up for a split second then then screen goes black but still boots up. So I changed the backlight ic and still have the issue. I have also replaced the battery. I Am at a loss to what the problem may be. I have fixed many iPhones as I am a cell phone repair tech but this one has me stumped. What else can I try?
Is dit een goede vraag?
Score -1
2 opmerkingen
I've seen this issue before. Can you post a picture of the LCD pins and surrounding components. Ill tell you what to do. You can try emailing me for faster response. Just go to my website.
door
Thank you for accepting my answer. Hope it will work out for you, good luck.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
kodyclarence, consider changing the coil as well since you already changed the IC
Was dit antwoord nuttig?
1 Opmerking:
Please if have picture with position of IC and coil thanks in advance
door
Voeg je antwoord toe
kodyclarence zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 260
