Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 Vragen Bekijk alle
Games play right, blank white screen. Help?
So I recently dropped my GBA SP on the ground and for some reason the screen is just white whenever I turn it on. I can hear the game working and it seems like everything else works fine, it's just the screen is totally unresponsive. The GBA SP is the AGS model 001 (The one with only a front-light). I really want to fix this and i'd like to do it at home. Can you please find me a link to a how-to video or a step by step walkthrough?
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Isaac, here are the guides. It is possible that your LCD broke, or that the connection came loose. Use the guides to open it up and check on the connection first.
Was dit antwoord nuttig?
Score 2
Hi there! If you were able to fix the problem, please let me know what you did. I have a similar problem, only my screen is black, with colorful vertical lines. So, it doesn't seem the LCD isn't working, it would seem maybe the ribbon to the screen is detached etc.
Score 1
I had the same problem and did what oldturkey03 said and it now works.
Mine is working but after startup it turns white and I need to fix it!
Voeg je antwoord toe
Isaac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 78
Altijd: 18,976
