Ga door naar hoofdinhoud
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
35 Vragen Bekijk alle
Replaced broken digitizer and reassembled screen not working
Hi,
I replaced my broken digitizer screen and after reassembling everything and power on, my screen turns on, but with lots and lots of white lines and parts of it black.
What could have happened?
LCD screen is dead? or is it something else ?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Chris, yes it could be a bad LCD. But it is also possible that your connector is not making proper contact. Double, no triple check your work. If that does not resolve the issue, replace the LCD once more. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the reply.
Well I tried everything by unplugging the video cable and replugging it back in and it stays the same.
So I have decided to order a new LCD screen, but can i just order any screen or it must be the same model/brand screen ?
Cause this screen is from the manufacture Chimei INNOLUX model N101ICG -L21 Ver. C1. I have tried searching for this model screen, but the places that sell this model screen are out of stock.
Any suggestion?
Thanks,
Chris
door
Chris, thank you for accepting my answer. I've always been a bit leary about just replacing LCD panels with other panels, unless I had a chance to look at the data sheets. In your case, take a look on here http://www.alibaba.com/trade/search?fsb=... and see what you find. Always contact the vendor first to make sure that it will fit, and that you can return it if not.
door
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,024
