Ga door naar hoofdinhoud
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Vragen Bekijk alle
power button will not put ipad to sleep
I've got an iPad that I'm fixing the screen on. I've got something bizarre going on that the power button won't put it in or take it out of sleep mode. However, it will power the iPad down. I'm pretty sure I didn't rip the power flex cable. Been down that road before. Any ideas?
Is dit een goede vraag?
Score 1
1 Opmerking
I was able to resolve the issue by turning off the setting for the smart cover. After that it worked like it should.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try turning the Smart Cover settings off. If the issue disappeared, then the magnetic sensor is damaged. You can also try the compass, which should also be dead.
If the problem is not caused by the sensor, try restoring the device
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ethan Grier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,137
