Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
Vraag afgerond
Why does my iPhone charge rapidly?
i had this iPhone that wouldn't charge, my 1 yr old sister got ahold of it and hucked it across the ground, i tried plugging it in and it charged (it was dead dead) in 5 mins, it was fully charged... is this bad??
Is dit een goede vraag?
3 opmerkingen
Ashton, first it did not charger, now it charges in 5 mins? Does is get hot? Could be a problem with the power management IC or the battery itself.
door
Maybe it didnt charge fully at all... Phone powered off in the fall, you plug it in... Wake it up.
door
oldturkey03... sometimes it gets warm... but rarely
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ashton, if it does not heat up and does charge the battery properly, as well as functions normal,I'd leave well enough alone. See what happens down the road. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 80
