Ga door naar hoofdinhoud
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Vragen Bekijk alle
How to Set the Clock on a 2002 dodge ram
I am having problems with the radio clock, I had to remove the battery and it changed the time. I dont know how to set the time on the clock.
Is dit een goede vraag?
1 Opmerking
I got a 2007 dodge ram how to set the clock time
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
leonel, for the standard radio you should turn the radio on, then press the "Setup" key, the hour will flash. Turn the station control knob left (ahead) or right (back). Then press the station control knob and the minutes should flash. Then turn the control for station again and this should set your time. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Followed directions to the letter. No go.
door
Could be diferent on each car. I had 2 little buttons on the right side said H & M use a pen to press them.
Sorry for the grammer i am dutch.
Score 1
2 opmerkingen:
Worked for me.
door
That did the trick, Dodge ram 1500 from the 2000'
door
You have to turn off the radio, then press and hold the time button until the clock flashes, then use the tunning control to adjust the time. Then press the time button again to finish.
Score 1
1 Opmerking:
The hour flashed but I couldn't get the minutes to flash
door
Old thread but figured it would help, I didn't know either Push in on the tune knob to change to minutes
Score 1
Voeg je antwoord toe
leonel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 83
Altijd: 42,861
