a dotted line is there on the screen, how to remove it?
a dotted line runs through in the middle of the screen..i don't know if it is a hardware problem or a software one..
Is dit een goede vraag?
sri hari, attach an external monitor and see if you have the same line. If you do, then it is most likely a software issue. Try all modes of your OS i.e. safe mode etc. If you do not have that line, then you most likely need a new LCD, especially if it is only a single line. this is most often caused by a bad LCD TAB. Hope this helps, good luck.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 4,233
