Ga door naar hoofdinhoud
Een 4GB 3,6" Touch Video MP3-speler van Sylvania.
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
What does a battery cost and where can one be bought?
door
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
door
It was not working and how to fix it.
1 Opmerking:
Um... what are you talking about???
door
My sony walkman wont turn on
Voeg je antwoord toe
henryr79 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 22
Altijd: 3,028
