Ga door naar hoofdinhoud
Desktops manufactured by Sony.
18 Vragen Bekijk alle
open the Sony Vaio VGC-JS to expand the hard disk
Sony VGC-JS All-in-One Model PCG-2P1M, hard disk failure
All-in-one PC solved all the screws, will not open.
How can I get the hard drive?
Urgently need help. Thank you!
Thanks for the drawing.
I can not release the stand. Is there a trick?
Is dit een goede vraag?
1 Opmerking
http://www.youtube.com/watch?v=Hl0QI69xn...
This is the solution!
All screws on the back and bottom. Then solve the edge gently with a small object.
Thanks for the video!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Mirjam Graf, this is a bit of a beast to open. Check the attached image, all the parts that need to be removed are highlighted. Here is a okay video that might be helpful to you too.
Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I need more help, thank´s...
door
Voeg je antwoord toe
Mirjam Graf zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,618
