Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone shows dead battery screen after replacing the battery.
I've already been charging it for 2 hours, but the phone still shows a dead battery screen (a red battery with a bolt underneath). I followed the instructions on this site and I'm pretty sure I connected every ribbon back correctly. How can I fix this issue? Do I just have to wait, leave it overnight or should I put the old battery back in the iPhone?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I had the same symptoms as you are having. A replacement battery solved my problem. At power up, the battery screen showed 1/3 charged, so you may have a bad battery or you may need a new dock connector. Also make sure connector #4 is securely connected. I had to put some tape on the top to make sure the connector stayed down.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jacob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 427
