Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
iPhone 4 network searching.No Network
Hello just like to ask.
Could this iPhone 4 logic board get fixed.The phone is not blocked but just seems to show network searching and can't pick up a signal.
I think there could be a problem here no to sure tho.
Is dit een goede vraag?
Score 2
2 opmerkingen
Yes them 2 chips are not on.I have them tho can take them of a spear board i have.Hmm now just need the soldering skills
door
Your image is a bit out of focus, but it does look like somebody applied a jumper. Remember that this ha now become common practice. You can get a circuit writer pen to close the loop if you have trouble soldering those very small pieces.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Your antenna coil is disappeared. If you replace it you will most likely have full signal again.
http://www.ebay.nl/itm/Apple-iPhone-4-Bl...
Was dit antwoord nuttig?
Het nuttigste antwoord
i have the same problem with iphone 4s simfree , he read the simcard but away searching.... any sugestion?
Score 1
iphone 4s network searching poblam
Score 1
make sure your time and date is correct that will fix it unless the black service wire is faulty or the clip is goes into is broken
1 Opmerking:
Thanks did the time and date still not working.Wire is fine.I been looking at a few pics and it seems am missing the blue coil
door
Voeg je antwoord toe
Hal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 26,151
