Ga door naar hoofdinhoud
Samsung Series 5 3G Chromebook. This laptop has a 12.1" Super Bright high-resolution, non-glare display ideal for web browsing.
8 Vragen Bekijk alle
What is the best way to clean the keyboard?
Due to a spilled beverage my spacebar no longer actuates properly. It will still register a keypress but it takes quite a bit more effort.
I am prepared to do as small of a tear down as necessary to get at the parts to clean them but I can't tell how much im going to need to do based on the pictures/text already provided and can't find a teardown video online.
I briefly considered a using a bit of water in the keys but since it turns on with a press of the spacebar I wouldn't even be able to work the spacebar until I let it dry out again.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
1) you can have 4 way
a) use spray to pressure(air ) from Radio Shack.
2) or use Infrared ultraviolet lamp for to dry the keyboard.
3) gum hair
4) a little trick( put the keyboard in submerged in rice by 8 hours)
God bless you
Was dit antwoord nuttig?
Voeg je antwoord toe
Nick Hanson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,579
