Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor je Apple Wireless Keyboard. Verbind je Apple-computer draadloos en geef opdrachten.
Factory reset or re-install firmware?
The recent firmware 1.1 update appeared to install correctly.
BUT, since the update the keyboard does not work properly - random ' characters and shift key not shifting case.
Attempts to reinstall 1.1 update or 1.0 updates are blocked by - "Your keyboard is already updated!"
Any secret key combo to reset the firmware or force a new (or old) update?
Or do I now have a useless keyboard?
Mac Mini. OS X 10.6.3 aluminum bluetooth keyboard (2007 3 battery)
Is dit een goede vraag?
Score 2
2 opmerkingen
What computer and OS are you using? Ralph
door
OS X 10.6.3 - it was the automatic update that included the keyboard firmware update that caused my problem.
door
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Het nuttigste antwoord
Here is the Apple paperwork for the update giving you problems. It appears to list steps to be taken after install. Maybe this will help you. Ralph
http://support.apple.com/kb/HT4010
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks for the suggestion.
Yes, I did that immediately. It reports the correct version number for the new firmware having been installed.
Of course, being very user friendly it reports the version in hex, but I know how to convert 0x141 to 321.
I am quite surprised Apple expects their users to do this. I have gained a new respect for the average Mac user.
door
did you try the troubleshooting from here ?
maybe this would help to get mor information about the non (or wrong) functioning keys
Score 1
1 Opmerking:
Thanks markus. It sees the same thing as any app. The keyboard is sending bad info.
I borrowed another keyboard and it works fine.
The problem is definitely in the keyboard and requires reloading of the firmware, which apparently loaded badly (despite giving no errors).
door
I have 2 Aluminum Apple keyboards ruined from an update of my macmini. pretty upsetting. apple is the new Microsoft. Apple updates used to be stable now they are shyt. one has non working keys while pressing shift another has a repeating number on startup for no reason.
This works...
resetting BT keyboard
Basically, you need to hold the power button the ENTIRE time you pair.
Try and see if it works.
The A1016 Mac wireless BT keyboard WILL work with Mavricks with no additional software, I dug out my old keyboard and put new batteries in and it attempted to paired up, but I had to remove all the other devices and then pair. After that you can pair up your other devices. I had to have patience, but it got there
1 Opmerking:
how did you remove all the old info from the A1016? I just found one that works perfect but when i try and pair with it, it asks for the keyboards pin number... and it say's the old owners name. i bought it from an electronic recycling store, so no way to contact original owner
door
Voeg je antwoord toe
Peter Jennings zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 62
Altijd: 55,553
