Ga door naar hoofdinhoud
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Vragen Bekijk alle
change Toshiba Satellite M40X memory from 2x 512MB to 2x 1GB
I want to change the memory from 2x 512MB (total 1024MB) to 2x 1024MB (total 2048MB)
Is dit een goede vraag?
2 opmerkingen
I am confused. Are you asking how to change it or what to change it to? Crucial recommends 1GB DDR PC2700 • CL=2.5 • Unbuffered • NON-ECC • DDR333 • 2.5V • 128Meg x 64 • • Part #: CT491152 for your M40X
door
I want to change the memory from 2x 512MB (total 1024MB) to 2x 1024MB (total 2048MB).
Sorry, you are right, the question ist what to do: i know the second bank is under the keyboard, bat I could not find the way what to do, how to open the back of the keyboard, which screws I have to unmount.
Thank or further info´s.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Wilfried Effer, one memory module is located on the bottom but another one can be accessed only if you remove the keyboard. The memory is under the keyboard but placed under the memory module socket cover. You can try and remove the battery and there may be one screw that secures this cover.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Wilfried Effer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 161
