Ga door naar hoofdinhoud
Ingebouwde Beats Audio™ levert ongecompromitteerd geluid van studiokwaliteit voor je muziek, video's en gameplay. Het is ook een krachtige allrounder, met dual-core prestaties, een briljant, helder 4-inch scherm en een toonaangevende camera.
Cracked touch screen panel
Afbeelding
My sister has a HTC Desire X phone.
Link: http://www.htc.com/nl/smartphones/htc-de...
It has a crack in the top screen only. The display itself is not damaged.
Can i replace the top screen. Where can i buy the parts?
Thanks in advance.
Afbeelding
Is dit een goede vraag?
Score 1
5 opmerkingen
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts.Thanks-Kiran
door
am using htc dsire x,my power button is totaly damagd,how to replaced the buttn....
door
Display and touch is damaged
door
My phone modle is htc desire.can I replace only a top screen glass.bcz touch with lcd display 's cost is high
door
My phone is htc desire x in which display has been cracked but touch s working.. Nd battery has a poor problem.. Can u replace battery nd display????
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
The screen can be replaced.
you can find the part on ebay:
http://www.ebay.com/itm/Touch-Screen-Dig...
cheers
Was dit antwoord nuttig?
1 Opmerking:
door
Het nuttigste antwoord
You will need an lcd separator machine to separate the lcd from the glass as they are glued together and it needs to be put on a special hot plate. Tutorial and lcd separator machine reviews can be found at www.lcdseparatormachines.com if your interested..
Score 1
1 Opmerking:
I have HTC DEsire X phone,which top screen is damaged but display is ok,it is working.May i replace the top screen.where can i buy the parts...pls hlp me..
Michael
door
Be carefull! Hade the same problem with my sisters phone. I first tried to replace the Digitizer Glas, but its full glued on the LCD screen when I tried to seperate both the LCD broke. You have to replace the whole display unit. I bought them from ebay. Didn't find it on ebay.com but on the german site. It's about 90€
http://www.ebay.de/itm/Original-HTC-Desi...
Even this is the whole TOP-Unit it was still not very easy.
Hope I could help!
Hello
I´ve found it on ebay more cheaper.
http://www.ebay.es/itm/380739140385?ssPa...
I´m waiting for receive it and create a guide to all of you!
1 Opmerking:
i needed a new glass for mine which is a htc desire 310 and found my glass on ebay it's coming form hong kong
door
hi, yes be careful , Bernhard is right the digitizer glass is stuck glued with the lcd screen and it broke with me as well so i needed to change the whole display unit. i found it on ebay and it's cheap :
http://www.ebay.com.au/itm/for-HTC-Desir...
i ordered it and still waiting for it
Had anyone got some kind of repair-guide?
I only found this video:
https://www.youtube.com/watch?v=hzRsLDah...
1 Opmerking:
Hello, I´m working on a repair guide, hope to finish it on this weekend.
door
Did anyone bought some not original lcd and glass replacer?
I'm not sure if they are worth anything.
1 Opmerking:
Hello, yes, I have bought 2 lcd+touch non original ( but with the HTC logo) and they works fine. The point is to glue properly the piece to the phone, because sometimes it comes out.
door
how to stick the digitizer to the display\front pannel
.please help
mine is not sticking
i cleaned it with glass spray also
what you have to do is heat the screen up with a hair drier or hot blower and then remove the screen
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 24,609
