Ga door naar hoofdinhoud
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Vragen Bekijk alle
I think I fried my iPod with the wrong power source.
I plugged my iPod into my inMotion speakers, but it turns out I had the wrong power adapter connecting the speakers to the wall. The speakers say DC IN 5V, and the adapter says 9V 1.11a.
I didn't know it was the wrong adapter until I inserted my iPod and the speakers (still off) started making a buzzing sound. The iPod then displayed: Connect to iTunes to restore. When I felt the upper back case, it was hot, and now it won't turn on at all. I've tried connecting to iTunes (nothing happened), reseting (nothing) and trying another power source (nothing).
What part of my iPod do I need to replace?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
mtbiker90, I'd start with the battery. Hopefully it is just the charging circuit of the battery that received a jolt of extra power and not the power management IC etc. Use this guide to replace the battery and see if it works. Hope this helps, good luck.
Was dit antwoord nuttig?
1 Opmerking:
I'll try that.
Thanks!
door
I tried replacing the battery plugged the ipod to the charger nothing indicated in the screen waiting several hours still nothing I think I burned out the ipod circuits hard drive or whatever makes it tick the replacing the battery was easy but didn’t solve the issue what should I do next
Voeg je antwoord toe
aaa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 597
