Ga door naar hoofdinhoud
MacBook Pro A1212 replace 1680 x 1050 with 1920 x 1024
Does anyone know if it's possible to replace a A1212 MacBook Pro 17 inch screen with a different resolution?
Currently i have 1680x1050 but i see a lot of 1920x1024 screens... Would it be possible to replace it. The video card supports the resolution on an external monitor.
Is dit een goede vraag?
3 opmerkingen
I think may be one for Ben to answer. From what I find its not possible but I would go with what he says. Ralph
door
How can i contact Ben for this? I would imagine that the resolution might be fixed from the screen and not the interface. If so it maybe is possible... I keep on hoping :)
door
Anyone?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I haven't tried this, but theoretically it should be possible...
First, follow this guide to remove the display assembly.
Then, use steps 18-32 of this guide and some intuition to remove the LCD panel.
Finally, follow steps 33-38 of the same guide for the installation procedure.
Good luck! Please be sure to post the results.
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Afbeelding
Handleiding
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Replacement
Moeilijkheid:
Moeilijk
1 - 2 hours
MacBook Pro 15" Core Duo Model A1150 LCD Panel High Definition (1920x1200) Afbeelding
Handleiding
MacBook Pro 15" Core Duo Model A1150 LCD Panel High Definition (1920x1200) Replacement
Moeilijkheid:
Zeer moeilijk
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
+ Ralph
door
And what were the results on this attempt?
Curious :)
door
sorry to be a bummer, but the apple logic boards have rom's that only recognize specific displays. If you install it, it will turn on but once the bootloader finishes and the OS starts to load, the screen will go black and you wont be able to brighten it
Voeg je antwoord toe
Questor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 3,162
