Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
20012 Vragen Bekijk alle
How do I clone a windows drive?
I want to partition a 750gb hard drive on my mac so I can run windows 7 on one partition and mac os on the other. I have a 160gb windows drive that I want to clone and install on my mac.
How do I do that?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
This get tricky as your not really running Windows alone here. If your were you would use a Windows cloning app. Here you can't as these apps go down to the file system block level (true cloning vs imaging).
Look for a Mac app that can do FAT32/NTFS file systems or use a Windows backup or file imaging program and not try to clone.
You could also use a syncing program to copy over to a network volume on to your own file server (or internet backup type of service - iCloud)
Was dit antwoord nuttig?
1 Opmerking:
I've used PartImage ( http://en.wikipedia.org/wiki/Partimage ) to great success in the past.
door
Het nuttigste antwoord
In my shop I use apps by Paragon Software. It will do NTFS/Mac/Linux, from partitioning, cloning drives, backups and even make bootable recovery images of your OS. Worth taking a look.
I would use OS/X install and set it up to dual boot, one partition for OS/X and the other for windows. It should create a small partition for the boot manager so you can select which partition to boot to OS/X or Windows.
Once you have that set up, then use Paragon to image your other drive over to the Windows partition. Note, however, if you pulled that Windows drive from a PC, it may take it some time (if it loads) to find the new drivers, etc, to match the hardware on your mac.
Score 2
Larry -
Don't forget to setup your Windows partition within Apples BootCamp application before installing Windows and your Windows apps & data.
Also, make sure to make a good backup of your current Mac volume before you start altering the partitions.
You may want to think about getting a larger drive to swap out with your current one. Then put your current HD into an external case. This gives you a clean slate to configure your HD for OS-X, BootCamp & Windows with plenty of space for apps & data for both.
Your other option here is using a virtual machine (VM) to run windows in using VMware Fusion or Parallels Desktop. These run within Mac OS-X as such you don't need to create a FAT or NTFS partition instead they create a storage drawer within your current Mac volume to hold your windows apps & data.
Heres a good rundown on the differences Best VM for Mac
Voeg je antwoord toe
larrypierceall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 7,082
