Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
White screen after drop
I dropped my iPod and now my screen is white. The iPod still makes sounds, gives me notifications, and the buttons do what they're supposed to.. I can even unlock it by sliding my finger across it, but my screen it just white. I can't see what I'm doing.. Help?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi
If youve dropped it then its likely the screen has gone faulty and will need replacing.
There are guides on ifixit to help you replace the screen but you do so at your own risk as its not easy.
You can also buy the part from ifixit
Regards
Update
Hi you can pick up a replacement screen for about $30 from ifixit found here
iPod 4G Display
there are plenty of guideas around to assist, but i do warn you its quite difficult if youve never done it before
Regards
The display is a 160x120 pixel 2" LCD screen. Afbeelding
Product
iPod 4G Display
$29.99
Was dit antwoord nuttig?
2 opmerkingen:
Thank you! Do you have any idea of how much that will cost me?
door
About $30 probably if not less
door
Het nuttigste antwoord
Hello! It may be the LCD is damaged or the connector may have just popped loose. I would follow the guide here to open the ipod up and just reseat the connector first. May save some money. If that doesnt do the trick than I would order a replacement screen and replace. Not terribly difficult to do. The screens usually run about $15-$20 online.
Hope this helps
Score 1
Voeg je antwoord toe
Lace zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 2,008
