Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
"Do Not Remove" Sticker
Battery replacement went fine. Works perfectly...but what about that "Do Not Remove" sticker under connection "6". Does it serve any purpose? I destroyed it getting off to uncover the screw underneath. Is it an Apple Police sticker? Should I go back and replace it with something like a square of electrical tape?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Don't worry, probably kind of warranty void. But if you change the battery you are probably not under warranty anyway!
In case you had a metallic part or other conductive material over it, you could put another piece of tape for security but it look it is the battery plastic envelope just over so no risk.
Picture from the iPhone 3GS Teardown for reference:
Was dit antwoord nuttig?
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,028
