Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Why is my display screen in black and white only?
I resently replaced my broken touch screen....since I put the phone back together I only get black and white images on my screen .... All buttons, apps and screen work perfectly... I just don't have any color.
Is dit een goede vraag?
Score 12
3 opmerkingen
What a wacky problem!
door
It happened to me too. Its on my iphone 5c. When I push home 3x I get camera. Any suggestions?
door
I found that screen in settings. Thank you
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Is the screen actually in black and white or could it be that its in reverse black on white contrast mode http://grab.by/Zgb
if it's the latter you can find the accessibility settings in your iPhone and turn it off.
Was dit antwoord nuttig?
Score 9
4 opmerkingen:
Stitchrobot - You're awesome!!
door
which one is the home button?
door
What is the home button?
door
Mine is doing this but I have a Google Pixel 2
door
Correct answer in my situation… Press the home button three times in succession and it will bring a menu option that says
"voice over"
"Invert colors"
"Zoom"...
You will most likely notice that the "zoom" option is checked… UNCheck this option and your screen will go back to colors!
Yea!!
Score 6
5 opmerkingen:
Awesome! Thank you so much as this has helped me!
door
Other experts could not fix problem, but you sure did, and many, many thanks
door
Thanks a bunch
door
Great brother,
It worked for me....thanks dude !!
door
Thanks I learned something New Today
door
tap your screen 3 times with three fingers. A menu will pop up. Touch choose filter and set to none.
Score 4
1 Opmerking:
Omg thank you so much! Todd Ramsey ☺
door
looks like a cable issue to me (connector) - unless it's a broken screen.
But hey, colour is overrated !
Score 3
I have LG Aristo that suddenly turned black/white
I tried everything, turning it off and back on, adjust settings, searched internet for help, etc...
Nothing seemed to work
)))UNTIL(((
I pulled down the screen at the top which give notifications and at the very top has signs of features that can be turned on and off by touch.
ie: WiFi strength, Sound, Bluetooth, Location, Rotation, Sync, Flashlight, Airplane Mode, Data, Battery Saver, Color Inversion and "COMFORT VIEW".
Clicked on 'COMFORT VIEW' and (((POOF))) everything went back to color.
Felt like I was in Wizard of OZ. LOL
Hope it helps fix your issue.
Have a GREAT Day!!!
Score 1
1 Opmerking:
This solved the problem completely!
door
On the LG XPad 2, I pressed the Hot Key once and that put it back to color.
Voeg je antwoord toe
Mytech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 49,463
