Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vibrate Switch Stripped Screw Help
Please refer to the following manual for the screw I am referring to:
iPhone 4S, Headphone Jack Cable, Step 32
The screw head is stripped. Im looking for a way to get this thing out and replace it. Drilling and tapping is out I assume because its so dang small. Any help would be appreciated.
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If you hold the back of the phone and push up while pressing down to loosen the screw. A small flat tip precision screwdriver typically works.
Superglue will work. I always prefer the Gel type.
I keep a bottle of ScrewGrab in the shop, you can find it on Amazon.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
You guys rock. Thanks for the tips. Ill give them a shot.
door
You could try using super glue or a similar epoxy to bind it to your screwdriver, then replace the screw with a new one. I suggest something along the lines of JB Weld or Loctite. As it's a small area to work with I suggest applying the epoxy to the screwdriver first, not the screw to prevent overflow/spilling onto nearby components! Good luck!
Voeg je antwoord toe
Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 340
