Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Where does this one-prong grounding clip go?
I am reassembling my iPhone 4S and have a small one-prong grounding clip that fell out after I removed the logic board and before I could see where it came from. It is NOT the camera grounding clip, I have that and know where it goes. It is a black rectangle 5mm x 3mm with a screw hole offset towards one side. A small 2.5mm ground prong sticks off perpendicularly from the opposite corner from the hole. any help on its location and orientation would be a huge help. I would post a photo but I can't seem to figure out how.
Is dit een goede vraag?
Score -1
1 Opmerking
it might be easier if you post an image of the clip
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
iPhone 4S Logic Board Replacement, look at step 19, your clip has a red dot on it. If this answer was helpful please remember to mark it accepted.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
5mm clip, this could be the bottom clip that covers the antenna wire cap connector at the top battery connector screw. The clip goes over the antenna cap, then the battery connector goes on, then the screw holds everything into place.
The clip is at the end of the blue spudger in this photo: http://guide-images.ifixit.net/igi/PI3sC...
door
Brad was correct, it is the antenna ground and goes under the battery connector. thanks
door
Where can you get a replacement piece or is it even really needed?
Voeg je antwoord toe
pickapair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 18,692
