Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een tablet ontwikkeld door HP in 2011, draaiend op het webOS-platform. Beschikt over een 9,7"-display en is beschikbaar in 16 of 32 GB. Reparatie is eenvoudig, maar vereist tijd en doorzettingsvermogen.
Battery Icon with question mark (?)
My HP touchpad is out of warranty. When I try to power it on it shows a battery icon with question mark in it. When it is connected to a charger the light flashes on the center button. I have tried all solutions posted on the web, with different button combinations, leaving it on charge for more than a day, using different cables, trying to leave it connected to a computer, etc. Everything brings back the battery icon with question mark and cannot do anything more.
Connecting to a computer with USB, makes the center button lights to flash, but cannot access the file system thru USB.
I thought changing the battery, but not sure if that will fix the issue.
Is there a way to reset to factory defaults?
Please let me know if there is anyway to fix this.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
7 Antwoorden
Filteren op:
Gekozen oplossing
Here's how to replace your DEAD battery: HP TouchPad-batterij vervangen
Was dit antwoord nuttig?
Score 6
It is more than likely not the battery, but that it is 'bricked' due to corruption of the boot-up firmware. Many people have had the issue, including myself, and resolved it by the methods at this link:
http://rootzwiki.com/topic/38786-tpdebri...
If this works for you, then thank all the people who worked to develop a solution especially 'jcsullins'!
Score 2
In french the solution is here:
http://lmorel3.fr/2014/05/debrickez-votr...
Score 2
my talet still has a question mark on the energy symbol i try all the website in the whole world i think.but It did'nt work. i try to charge It on the computer It did'nt work, i bought a new charger It still did'nt work. now i'm just bored at home
Score 1
1 Opmerking:
IF you are bored, you should get a new iPad.
door Deel
Resolve this issue...
Hello I got a LG phone and when I turned on I saw the question mark on the battery I plugged In for a hour I stayed off it I plugged in for the whole night WHAT SHOULD DO????
1 Opmerking:
did you ever figure this out? i have same problem email me skram84@gmail.com
door Deel
My new stylo 5 phone has its original charger it shows a question mark when plugged in. What can I do to fix it?
Voeg je antwoord toe
Rani zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 47,262
