Ga door naar hoofdinhoud
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Vragen Bekijk alle
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Is dit een goede vraag?
Score 2
2 opmerkingen
can you attach an external monitor and see if you get anything? Any post beep's?
door
Use this : Dell AC Adapter LA90PM130
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
Was dit antwoord nuttig?
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Voeg je antwoord toe
Amit Lal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 4,029
