Ga door naar hoofdinhoud
De Wii werd in november 2006 uitgebracht in Noord-Amerika en was Nintendo's eerste spelconsole voor thuis die direct internetconnectiviteit ondersteunde, met ondersteuning voor zowel online games als de digitale distributie van games en media-applicaties via het Wii-winkelkanaal.
Wii Click of death.
My Wii is a few years old and has decided to CoD (Click of Death) http://en.wikipedia.org/wiki/Click_of_de... any time ANY disk (GC or Wii) is inserted. it still spins. but won't read. this did not happen suddenly. at first it would not read certain disks sometimes, then it wouldn't read most disks sometimes, then it wouldn't read any disk, and now, it wont read the disk and brings up the Wii's BlSoD (Black Screen of Death). Is the disk drive repairable or is it time to swap disk drives or is the Wii cooked with a side of mashed potatoes?
Is dit een goede vraag?
Score 5
1 Opmerking
laz is not dirty, i think it's time to set the dinner table...
door
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Het nuttigste antwoord
Superchu, sounds like the laser is either dirty, may want to try to clean it, or "cooked with a side of mashed potatoes" . Most likely it is time to replace the drive.
Was dit antwoord nuttig?
Score 3
You can pick up a replacement drive on Ebay for about $20-25 dollars. Fairly easy to do yourself as long as you have a tri-wing screwdriver also found on ebay cheaply.
Score 2
Superchu did you figure out what it was by any chance? My Wii is clicking too and everytime I put a disk in it try's to read and then a page pops up saying eject the disk and restart the Wii and check the manual troubleshoot guide. So if it was just the lazer that is awesome but if it is the disk drive it would be nice to know so I can just get it out of the way. My 6 yr old wants on there badly and I feel bad not having it fixed yet. Thank you for any help you can give!!!!!
1 Opmerking:
Mine is doing this same thing....... what was the conclusion?
door
Ordering new drive for mine
I had this same problem. First time it happened, I replaced the entire drive. Then it happened AGAIN, but this time I noticed that one of the little helical gears had split and detached from its shaft. Someone kindly posted a ctb file of the gear, so now I'm trying to 1) convert the file to stl or something more common and 2) find a 3D resin printing service who would make 2 or 3 of these for me.
https://www.reddit.com/r/consolerepair/c...
I'll also be adding a screw to hold the shaft in place, as mentioned in this post.
https://github.com/BiegunskiEr/Wii-Disc-...
Replacing a tiny piece feels so much better than replacing the entire drive.
Voeg je antwoord toe
Superchu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 109
Altijd: 20,781
