How do I get the door panel off
I am trying to get the door panel off so I can fix the latch.
Is dit een goede vraag?
Kevin, try this :"
Removal & Installation
1. Disconnect negative battery cable. Remove 2 screws and armrest cover. Remove window crank handle (if equipped). Starting with front edge, pull out lock lever trim. Remove upper corner trim by pulling out at top edge and pivoting down to clear tab at trim panel. Remove 2 caps covering 2 assist handle screws. Remove 2 screws retaining handle to door.
2. Remove screw at front edge of accessory switch mount plate (if equipped). Remove plate from trim panel. Remove electrical connectors from switches. Remove door courtesy light assembly from door panel. Remove trim panel retainers from door. Remove trim panel. See Fig. 1 . Remove lock rods from door lock motor. Remove screws or drill out rivets and remove door lock motor. See Fig. 2 and Fig. 3 .
To install, reverse removal procedure.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 73
Altijd: 17,797
