Ga door naar hoofdinhoud
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
screen doesnt turn on
it turns on ican hear it but the screen doesnt turn on
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
jasonrussell, that could be caused by two things. One would be a bad LCD and the other a bad backlight fuse. Try to angle your LCD against some light and see if you can make out some shadows. Usually I use a darkroon and a flashlight angled against the LCD to determine a bad backlight. Anyhow, attached is a picture about the backlight fuse. It is annotated in Russian :-) and the "F" shows the fuse. Use a multimeter to check for continuity. You also want to check the LCD cable as well as the connector for any damage, corrosion etc. you can also check on here. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
jasonrussell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,128
