Ga door naar hoofdinhoud
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
How do I reset a frozen screen on my razr?
I was in a call, & when I tried to end it, my phone froze. Now it is stuck with the call display still showing, and it won't let me do anything. I can't turn it off, and with no battery to take out, I have no idea how to reset it.
Is dit een goede vraag?
Score 8
1 Opmerking
my razer cannt switch on.. only after the razer logo out then its off again.. helep helepp
door
Voeg een opmerking toe
13 Antwoorden
Gekozen oplossing
I would suggest removing the battery for a few minutes. It's not the most difficult thing to get to.
Motorola Droid RAZR Battery Replacement
You don't need to actually remove the battery, just unplug the terminal for a few minutes.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
My phone is not working after battery replacement and stopping on Intel what I have to do please help
door
Het nuttigste antwoord
My phone did the EXACT same thing. This is the fix that worked for me since the Razr doesn't allow you to take the battery out:
Hold the volume DOWN button + Power Button down at the same time for 10-15 seconds and the phone will power off. It might just restart. If it doesn't, wait 20 seconds then power it back on.
VOLUME DOWN BUTTON + POWER BUTTON held down at the same time for 10-15 seconds. This will power the phone down. Then you can turn it back on!!
Score 25
18 opmerkingen:
Thanks so much! It worked!!!
door
Worked for me too! Thank you!
door
It worked for me too. Thanks for this very helpful information.
door
Great Advice!!!!!!!!! It worked!
door
I was in a panic!! This worked!!!
door
13 commentaren meer tonen
Yay! Thank you for the advice of Volume Down & Power at same time for 15 seconds, it worked!!!
Score 1
1 Opmerking:
yes this was the only thing that worked for me thanks.
door
hold volumn down + power button together worked for me to. thank you
Just worked for me too! thanks
don't take your battery out voids the warenty power + volum down works
Omg you're amazing, was about to bring my droid razr into Verizon because nothing worked and it's been frozen since yesterday, but this simple trick worked! Thanks!
2 opmerkingen:
Does not work all of the time. First, just to get the Motorolla icon to appear can take 20 attempts. Then, most people are afraid that a complete restore will him to lose all files - does not happen with my Iphone - so he is left with turning it off, then if on again, same problem. Also, his requires to hold onto power button once green light comes on to get to any menu. Solution - get an Iphone.
door
Worked great for me. It only took once, not twenty. Didn't lose any files.
door
wow - genius! thanks! I was about to head to Verizon also!
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!I was also about to take it to verizon because nothing worked including holding down the power button...holding the volune down at the same as the power worked! Much appreciated :)
I did that. But everytime I turn it back on it freezes turning on and its been like this for two days now. What do I do now.
thumbs up !!!!!!!! bravo !!!!!!! it worked, by pushing volume down + power button at the same time. great........ mir of pakistan
My Motorola Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
What should I do to recover it.
Thanks....
i have the same problem My Motorola Droid Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
Kindly guide....
Voeg je antwoord toe
susyq zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 77
Altijd: 29,098
