Ga door naar hoofdinhoud
The Canon EOS Digital Rebel XS is an entry level DSLR with a 10.1 MP sensor released on the 10th of June 2008. Also known as the EOS 1000D and the EOS Kiss F.
How to deactivate AE Lock and multiple shots
I believe the camera AE lock "*" is applied and I am unable to deactivate it. Every time I try to click a picture it takes 10 seconds and then multiple shots (7-8 ) are clicked.
I want to deactivate it and fix the shutter speed so that it won't take 10 seconds to click a picture and it takes a single shot instead of multiple shots
Is dit een goede vraag?
Score -1
1 Opmerking
Kuljeet, have you tries to turn the mode dial on the camera's upper left side to manual?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Kuljeet, check your manual. Page 75 will tell you how to set Manual exposure etc. as for your multiple pictures, it does sound like you are in drive mode. May be you could try to reset all the settings to default.
Attached image is from the manual and shows how to perform a reset. Just in case you need the manual, download it from here.
Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kuljeet zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,185
