Ga door naar hoofdinhoud
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Vragen Bekijk alle
Is the optical drive connector PATA/ATAPI or SATA?
On the Apple Mac Book Pro A1226,
On the iFixit Guide about optical drive replacement, there is one type of connector :
PATA / ATAPI connector
But on the iFixit Guide about dual hard drive, the solution provided :
9.5 mm SATA Optical Bay SATA Hard Drive Enclosure
offers an other type of connector.
SATA Connector
How to know which connector is the correct one on my model ?
On iFixit, there is clearly a problem because the part sold to hold the disk on the optical bay cannot match.
Unibody Laptop Dual Drive Afbeelding
Product
$24.99
Is dit een goede vraag?
Score 2
1 Opmerking
Just to clarify things here: Depending on your model of system (iMac or MacBook Pro) you could have a PATA (ATAPI) optical drive or you could have a SATA optical drive (newer systems). The HD carrier used to replace the optical drive holds a SATA HD in either case and converts the I/O in the older systems to connect to the PATA interface. In the case of the newer carrier it does not convert the I/O as it's not needed. Sales is looking at clarifying the description so this is clear between the carriers.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Hugo,
This is the enclosure that you need:
[gekoppeld product ontbreekt of is uitgeschakeld: IF107-078]
You can verify it by checking your system info under Hardware>ATA . I have a A1226 as well and im sure that it is ATAPI and not SATA.
Well spotted
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Good catch I've notified the sales group so the products can be verified and descriptions can be corrected
door
I've edited the optical drive replacement guide, now I'm just waiting to see if they approve it.
door
Jay which guide did you post the correction to?
door
Voeg je antwoord toe
hugo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 6,624
