Ga door naar hoofdinhoud
Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive
Wat je nodig hebt
  1. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Battery: stap 1, afbeelding 1 van 3 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Battery: stap 1, afbeelding 2 van 3 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Battery: stap 1, afbeelding 3 van 3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, RAM Shield: stap 2, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, RAM Shield: stap 2, afbeelding 2 van 2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Upper Case: stap 3, afbeelding 1 van 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  4. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 4, afbeelding 1 van 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  5. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 5, afbeelding 1 van 1
    • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
  6. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 6, afbeelding 1 van 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  7. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 7, afbeelding 1 van 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  8. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 8, afbeelding 1 van 3 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 8, afbeelding 2 van 3 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 8, afbeelding 3 van 3
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
    • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
    • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
  9. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 9, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 9, afbeelding 2 van 2
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
    • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
  10. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Optical Drive: stap 10, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  11. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 11, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 11, afbeelding 2 van 2
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive.
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
    • Lift the optical drive up and out of the computer.
  12. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Optical Drive: stap 12, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Optical Drive: stap 12, afbeelding 2 van 2
    • If your new optical drive already has brackets on it, you'll only need to transfer the data cable to your new drive. Skip the bracket removal steps below.
    • Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
    • Rotate the drive and disconnect the orange ribbon cable from the optical drive.
  13. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 13, afbeelding 1 van 1
    • Remove the two Phillips screws securing the mounting bracket to the rear of the optical drive.
  14. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 14, afbeelding 1 van 1
    • Rotate the drive and remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  15. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Dual Hard Drive: stap 15, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive, Dual Hard Drive: stap 15, afbeelding 2 van 2
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  16. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 16, afbeelding 1 van 3 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 16, afbeelding 2 van 3 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 16, afbeelding 3 van 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
  17. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 17, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 17, afbeelding 2 van 2
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
  18. Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 18, afbeelding 1 van 2 Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive: stap 18, afbeelding 2 van 2
    • Use two Phillips #1 screws to secure the drive to its enclosure.
    • Transfer all brackets and the optical cables from the drive you're removing onto the new enclosure, and reverse the procedure to install the enclosure in your MacBook Pro.
Conclusie
72 andere personen hebben deze handleiding voltooid.
Jake Devincenzi
117.301 Reputatie
57 handleidingen geschreven
14 opmerkingen
i dont see how any of you guys installed the hard drive. the ATApi on the mother board is a different from the hard drive. any one know the solution to this? please help
kevin nguyen - Antwoord
iFixit sells a SATA to ATAPI cage for the hard drive. You'll get slightly slower speeds than via a SATA connection, so if you're thinking of installing an SSD I would move the spinning hard disk to the cage. The photos shown in the guide after step 16 are incorrect, as they reference the SATA optical drive included on newer MacBook Pro models.
kogepathic -
Had trouble getting MBP to recognise the secondary HDD in the Optical Bay Enclosure. I could hear it spin but Disk Utility did not recognise it.
After a few hours I realised I did not push the orange SuperDrive ribbon cable into the logic board (Step 10) all the way in.
Lesson: Be gentle but not too gentle! Everything works now.
jerlou3 - Antwoord
Hi,
Can someone help me?
I think that the optical drive has a ATAPI connection, not a SATA connection, as it's showed (image 20). Am I right?
Consequently, the second disk enclosure has to have a ATAPI connection for the motherboard and a SATA connection for the HD.
Additionally, the optical drive to USB cable has to be a PATA to USB.
Any help will be appreciated!
filipebrodrigues - Antwoord
Email sales [at] ifixit [dot] com
Scott Dingle -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 71
Altijd: 74,304
