Ga door naar hoofdinhoud
Reparatiehandleidingen voor een groot aantel Panasonic digitale camera's.
348 Vragen Bekijk alle
PC does not recognize my camera, please help
I took a picture while my Panasonic Lumix DMC-ZS10 was connecting to PC and now it will not connect to my PC. I've tried taking the battery out, restarted the computer, turned off/on camera. Nothing works.
This error flashes when I try to connect "Picture is displayed for 4:3 TV for 16:9
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It is really not an error that flashes. That is the output setting that is detected whenever the A/V cable is detected. I would start by resetting the camera to the default settings. Go to your setup menu and use the reset functions. You can also try to set it to USB first and see what happens. If you do not have the manual, download it from here.Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Polly zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 16
Altijd: 2,565
