Ga door naar hoofdinhoud
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Vragen Bekijk alle
Vraag afgerond
What could be wrong with iMac display backlight other than CCFLs?
My iMac 20" (early 2008) recently lost all backlight. Here are the symptoms:
1) On startup, and on wake, the screen reaches full brightness for less than a second, then goes dead. This is why I think the CCFL's themselves are not the problem, but rather something that is supposed to be powering them.
2) For the past year, the screen simply went dimmer than usual, rather than going out completely. So I suspect that something half-broke a year ago, and is now fully broken.
3) Shining a light on the screen reveals that the LCD itself is working just fine. Also, my external monitor works, so at least the video card is probably okay.
Things I've already tried:
Resetting the SMC, PRAM and NVRAM
Are these symptoms consistent with a specific known problem? Is there anything else I could do to try to diagnose what the issue is? I'd rather not start replacing parts that aren't necessarily broken.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Replace Apple part # 922-8507 (inverter board). To test to see if this is the issue, hook it up to an external monitor. If the external is good, replace the part.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Thanks for the suggestion! I will check this out.
door
Wow... two months on back order but it finally arrived, and it worked! Thanks!
door
Did you try booting on the Safe Mode? Does the same issue return?
1 Opmerking:
I tried booting in Safe Mode, but the screen problem is unchanged.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,581
