Ga door naar hoofdinhoud
The LG EnV Touch VX11000 is a cell phone released on June 5, 2009 for the cell service carrier Verizon. It succeeds the LG Voyager VX10000, and it comes with a flip design, black case, and CDMA technology.
3 Vragen Bekijk alle
Vraag afgerond
How do I fix a water damaged EnV Touch VX11000?
I bought a water damaged EnV Touch on ebay in an attempt to fix it. The owner said that he went swimming with the phone, and that it did not turn on afterwards. I took the phone apart, and found only a few spots were there was corrosion; there was no moisture anywhere, but the water indicators were red. I cleaned the corrosion with Isopropyl alcohol, and I also cleaned off the motherboard. However, when I turned the phone back on, it still did not work. I think one of the components of the phone must be fried (maybe the mother board, and/or one of the connectors), but I don't know how to find which ones are fried.
Any suggestions? Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Jon, the first thing (right after properly cleaning it, which you have done, but may want to do again) is to replace the battery. Water and cellphone batteries do not mix at all. Once you have a new battery, and made sure that the battery connectors are properly cleaned and seated, recheck the phone.
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
Ok great, I'll give you an update when I get a replacement battery.
Thanks for the help!
door
The new battery worked! I just have to replace the lcd screen now. The inside one is cracked and does not turn on.
door
Jon, excellent. Great way to start, keep us informed.
door
So I replaced the screen, and there is a lock code on the phone. The person I bought it from doesn't reember what it was. Is there anyway I can reset the phone either with a code or internally without going into Verizon and paying them do it?
door
Follow the instructions on this video :)
door
3 commentaren meer tonen
I think I'll try that. My phone been water damage for about 6 months. I hate the new one so, so much that my mom bought me. It's a Pantech 1. Please help!!!
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 738
