Ga door naar hoofdinhoud
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30 Vragen Bekijk alle
Vraag afgerond
Opening the case to get to the fan
Just how do you get this laptop open? Removed all the screws from the bottom, HD, battery, and seems there is a screw that is under the keyboard around the < > keys that has to come out from the top. I am trying to get to the fan to clean the blades as they are encrusted with gunk.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Clint, take a look at this. It should definitely get you to the fan. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Remove the silver plastic cover from on top of the keyboard and remove it and remove the screws.
Score 1
1 Opmerking:
on the 300D there is 5 screws underneath the keyboard
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 8,156
