Inleiding
Are you having issues with the Wi-Fi connection on your iPhone 7? It might be time to replace the Wi-Fi diversity antenna. Follow this guide to restore your Wi-Fi connection.
Wat je nodig hebt
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Gereedschap gebruikt in deze stap:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap.
Skip the next three steps.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Apply a suction cup to the lower half of the front panel, just above the home button.
Gereedschap gebruikt in deze stap:Tri-point Y000 Screwdriver$5.99
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
One 3.2 mm screw
34 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Qual’è e dove si trova l’antenna dei dati cellulare? Non quello del Wi-Fi
questa guida risolve il problema del wifi grigio?
vyřešili jste problém?
Is this a potential fix for an iPhone that won’t allow the wi-fi to be turned on? The phone has been fully restored to factory but still won’t allow the wi-fi to be turned on. It is crossed out in the Control Center, and won’t allow it to be toggled on in the Settings.
Hey i have same issue with wifi did you get any solutions?
